Availability of 2019 Release 2 (10.07.01.32) OpenSite Designer, OpenRoads Designer, OpenRail Designer from Bentley Software Download
It has come to our attention that the 2019 Release 2 (10.07.01.32) has a problem with the reprocessing of templates. This results in displaying both the correctly updated mesh and associated linear features, as well as the previous mesh and linear graphics. This problem arises after dealing with changes resulting from edited control geometry residing in a reference file(s).
Given the severity of the issue we have removed this version from software downloads. Rest assured we are working on a solution that repairs affected files and will post the new version once we have verified the fix and passed QA. When available you will receive a notification in the Connection Center to download the new version.
Products affected
Symptoms
Template mesh objects and associated linear features appear to be duplicated with one instance being ‘static’ after an update to control geometry.
If you have specific questions or concerns over this please contact support.
Ian
