Error importing .dat file in Subsurface Utilities Model
I'm trying to import a utility model from SS4 to OpenRoads. I followed the instructions here. I load my .xin file, my .dat file, and my .sdb file. I didn't load a .idf file, but I'm not sure if that's necessary.
Here are the issues I'm having:
1. There is nothing in my Project Configuration dropdown menu to choose from. ( I guess I'm not sure if this is causing issue #2 below).
2. After I click OK and everything loads, I get this error below, which I'm assuming refers to the .dat file. I can't get any .dat files to load at all. I've tried several from other projects as well.
3. I also got this error below when I reloaded the Project Explorer tree.
Any idea what I'm missing? The process to import these files appears pretty straightforward, but it just isn't working for me. Any help would be appreciated.
Jen
