Hi
What would be the best practise to edit (add new line and curves) in existing horisontal and vertical geometry, without ruin the corridor and civil cell.
I am using OpenRoads Designer Realise 2 Update 7
Sigfús
Hi Karon,
Are you adding the geometry to the start or the end, or are you looking to inster elements in the middle of geometry ?
Simon Pegg
Bentley Civil Support
Hi Simon
I want to add new elements to the middle.
I think I have found a solution... creating new element and using "Complex Redefine"
HI,
I have a question to Simon Pegg response.
Would you use two different functionalities for modifying geometry at start and end rather than in the middle?
I have been using "Complex Redefine" for both locations, however, it is not always working the way I want, especially when the redefinition has to happen at start of alignment.
Thank you
Vera
