when i am importing feature definitions from xin file to openroads connect , after creating xml file. i can import xml file at element templates, no problem. but i cant import them to my feature definitions ("link active feature styles is missing") only i have import option and when i try to import xml file by this way, there is an error. thats why i can not use my SS2 feature styles especially for my templates.
thanks in advance.
Evren
Are you using the XIN migration tool? (It uses a spreadsheet and converts your XIN into 3 different XML files used to import into ORD.
Are you using the XIN Migration tool?
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/40487/video-migrating-xin-to-feature-definitions-feature-symbologies-and-element-templates
Dear Jerry,
thank you for your help but my problem is to convert xin file of SS2 to openroad designer 2019. I use power inroads SS4 to open and convert xin file. after that i used migration tool but i think, no name matchs at FD, FS, ET and nothing imported to xml file. all names is included in missing report. actually, i am trying to update my company from SS2 to openroads designer, is it a good idea?
Did you watch the video? In the delivered Workspace they used to deliver Migration tools but now they are a download from a Wiki.
Originally, there was an Element Template Utility that could write Element Templates from an XIN but since more granularity was needed, there is an XIN Extractor that relies on a spreadsheet to map XIN to XML file for Element Templates, Feature Definitions and Feature Symbologies. This video explain that process - focussing on Survey only.
Below link, explain in detail, thanks for your interest
https://www.youtube.com/watch?time_continue=1&v=vFjvtZybWZQ
