Is there a way to export alignments and profiles to CAD POLYLINES, and not SPLINES?
Patrick
Hi Patrick,
Can you please check if, when you "Save As" the file as dwg, select "Options" button, and from the "Save As DWG / DXF options" dialog box, change the setting to "Polyline" as shown in the image below:
Answer Verified By: Patrick Richer
That's exactly what I was looking for. Thanks!!
