Superelevation not applying to corridor
Hey I had to make some updates to this template with the edge of pavement alignment and when I went back to check how things went, the Superelevations aren't applying.  I detached and reattached and tried to reset it but it's not working.  You can see in the XS that the point control is pointing at it, but the point isn't going up to it.
Station range is right, point name is right, reference is right (well it's the CL), I reprocessed in the intersection cell, and was about to redo the super attachment, but that's a bit much and wanted to ask here what's happening before I do anything else.
