I have done the Vertical design but the Ground is showing in different shape and In different co-ordinate and my design is in different co-ordinate but in the plan the triangulation and horizontal design are in the same co-ordinate can any one guide me what is the issue..Plz
Hi Madan,
Can you send the dataset to check the issue here.
yes I will send u
Please detach the reference from the "Profile View". You will need to be in the "Profile View", go to "References" and detach terrain model file reference, that has got attached. This will detach the terrain model from the profile view and not plan view.
Answer Verified By: Amita Shinde
Thank you Madam it works as you said Great support from Bentley...
