This is not helpful. It is however, very presumptuous.
You cannot assume that just because a feature definition is of the drainage or sanitary type that a prototype is required. In a GREAT many cases, all we care about is 3D modeling for purposes of conflict detection. No drainage analysis of any kind is desired. This is especially true of sanitary systems even if I am designing a new sewer extension, because most of the time, the owner will tell me what pipe size is desired/required. In my 30 years of civil engineering, I can count on one hand where a commercial or residential development required any actual flow analysis of the sanitary system. Others, of course, live and work in a different atmosphere and this may not be true for them. For them, they will make sure to add the proper prototypes in their library.
For me, and others like me, all you have done is create more work in configuring the library. Please stop, because I have plenty to do already.
OK. Now, an inconvenience has become a trial. A little background: My client is very decentralized. The drainage group and utilities group are very nearly autonomous. They have separate SUDA libraries. Drainage is in one. Existing utilities are in a second and proposed utilities are in a 3rd. Yes,the 2nd and 3rd libraries could be combined, perhaps they will.
You will note that prototypes are only loaded from a single library and only from the active DGN/DGNLIB. So, in the utilities library, I cannot utilize the drainage prototypes, even though I only need a dummy.
I work for the utilities group which includes sanitary sewer. Easy enough for me to add dummy prototypes, right? Wrong. If I add a prototype in the utilities library, it can be assigned while I am editing the library but is never available in the project, because it never exists in the project because it never existed in the hydraulic seed. I cannot trick it by making a prototype with the same name as one in the drainage library because the prototypes are keyed off a GUID, not by name.
Also, please note the dialog below. Why are you providing prototype in the dialog when it is an inactive control? Taunting perhaps?
Given my clients setup, I don;t know if there is a solution to this quandary in current software. I'll post here if I find it.
Robert Garrett Senior Consultant
www.envisioncad.com
So, here are the only solutions available which I have found in the current version of software:
Suggested solution from Bentley:
Dog gone! This hole keeps getting deeper. There is yet another gear in play for this problem. A contributing aspect is the use of variable SUDA_Use_Haestad_Conduit = 1. Because of this variable, then both drainage and sanitary feature definitions are looking for a Haestad conduit library and hence a prototype. So, the check for prototype is less arbitrary than it appears. But there are a LOT of moving parts here which make life very difficult when the hydraulics engineers are different than the sanitary engineers.
A third solution to my problem then is to have completely different workspaces between utilities and drainage. This is probably not objectionable to my client but creates a hardship for all my client's consultants.
Which leads to a suggested better solution in the software. Forget the variable SUDA_Use_Haestad_Conduit = 1. It is too heavy handed and is built upon a mountain of assumptions. Instead, if a conduit has a prototype then use the Haestad conduit library, if it does not then use the feature definition conduit table. Simple and explicit and eliminates assumptions. Coupled with this, then prototype[es must be able to be read from a library rather than only from the active DGN.
