Can anyone tell me whether there are any tools for editing the classification of points within a point cloud - specifically, where a group of points in a particular area are classified incorrectly? I picture placing a shape around a group of points and changing the classification to ground instead of created.
I assume you are using OpenRoads.
The tools can be found on the Reality Modeling>Retouch ribbon. It helps to have the Reality Model Presentation dialog open while you are making edits so that you can turn various classifications on and off.
Is there a video or documentation on how to use the tool? I need to change the classification of points inside an irregular shaped area. The tool seems to ask for two rectangle corners, and after the second corner is selected, does nothing.
Hi Ray,
I would like to learn more about this subject (Reality Modeling) to apply it in ADA curb ramps
Hi Andrew,
To select an irregular shape, you need to select the "Shape" mode (2nd button from the left):
In the "Source" setting you need to select all the classes you want to move points from. And, finally select the class you want to move points to in the "Destination" list.
HTH,
Pascal
