Hopefully someone can help me figure this out. I am attempting to attach georeferenced aerial images (jp2 files) through OpenRoads. The images have a different coordinate system than the drawing file. OpenRoads does not give me the option to change the 'Inherit GeoCS from Model' to Not Inherited, so that the images show up in the correct place with the correct scale. I have tried changing the default attributes, but it still is not attaching them correctly.
I can attach them in InRoads Select Series 4 just fine and then open them up in OpenRoads, but I don't necessarily want to rely on using older programs. I have checked the preferences for both programs and they are identical.
Any ideas as to why this is happening? Is OpenRoads not picking up the georeference from the file?
Can you attach them to a DGN called Aerial and then reference that into the files you need them in?
Yes, this is what I'm trying to do. I'm just wanting to do it in OpenRoads.
Is it just greyed out? Both files need geo settings. Main and reference.
Double clck the image from Raster Manager in the information box look for the geometry tab at the bottom is the inherit setting.
The issue is happening as I'm trying to initially attach the aerials to the DGN file, after I have attached a coordinate system.
I see that I am able to change it after the fact, but at that point it does not move/scale the aerial correctly. In SS4, I have the option before I attach them to select 'Not Inherited'.
