I originally posted this question 2 years ago under "ORD Contour Text Orientation and how to remove the m in the Contour Text"
In InRoads SS2, it is possible for the top contour text to be always on the uphill side of the contour line. How do this in ORD?
David Stewart
The "Label Terrain Contours, Text Alignment, Up slope" command is not working and has to be done manually. If I use the "Follow line" option and am careful as to where I place the line, it works.
I am working with a large mine site with lots dips and doodles. Having the text with the "Up slope" orientation is a great help.
David E. Stewart
Sr. Civil Modeller
Vancouver BC
David.Ewen.Stewart@Fluor.com
