Why can't I add a keynote (and other) reference to my P&P Sheet Definition DGNLIB? I added the references but when I generate these sheets nothing shows but the plan and profile.
ORD Rel 2 Update 7 Ver 10
how is this keynote referenced? an attached file or a cell? If attached file, have you check if path is correctly set on absolute or relative?
Marc, thanks for the reply.
I tried referencing both as a dgn, as dgnlib and as a cell. I tried referencing absolute and relative.
Can you upload your files here: https://bentley.sharefile.com/r-r784bc6214004c6ea I will investigate the issue
Can you also provide some explanation on the files and possibly an example of how the final sheet should be.
Marc, I figured it out. I didn't have the referenced DGN file in the project folder.
Thank you for your help.
Answer Verified By: Marc Blancher
