Power InRoads V8i (SELECTseries 4) 08.11.09.04
In Geometry --> View Geometry --> Vertical Annotation
I am trying to edit the cardinal point leader length, and it seems to be stuck at an arbitrary minimum of 300.
Changing 'Segment 1' to a value of more than 300, increases the leader length to that amount.
'Segment 1' values of less than 300 result in no change. (stuck at 300 length)
'Segment 2' value changes result in that leader length value change.
I am in a 1:1 drawing with no annotations or scales used.
Christian,
It is actually Segment 2 that automatically sets a minimum length to fit the text. For example, you can see below that my Segment 2 is set to 0, but the line length is 22.68. This is working as designed.
If I put a value greater than the 22.68 then it will extend Segment 2:
Holly,
I guess I am just wondering where I could look in my options to figure out why your 'minimum length' is 22.68, while mine is 300.
I am at a 1:1 Scale, and am not using any annotation text or scales.
The only thing I can think of, is that my profiles are plotted at 200 scale. 10 Vertical to 1 Horizontal.
