My corridor handles are disappearing when I process a corridor. I have been working in these files for days with no problem, but the past day when I get into any file to update it, the handles immediately disappear once the process corridor is complete. My view attributes --> constructions are turned on and the levels are on, and since they were showing before I process the corridor, I can't figure out what is making them disappear. I have tried the key in civil display browser --> Repair relationships to see if maybe the file is corrupt but that doesn't make them reappear and the files themselves seem to be working for everything else that I do. I have had them disappear before, and after a couple times processing the corridor they come back, but this time they seem to be permanently gone no matter how many times I process them. I can see the corridor and template drops under the Project Explorer and everything looks like it is pathing to the correct places, so I don't believe it has lost a reference to anything. The only way I can select the corridor to update it is to turn the 3D model on in the 2D view and select it that way. Any ideas? Thanks in advance!
Is the corridor visible in Project Explorer?
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Hi, I pick up this thread as I have exactly the same situation but in power rail.
The corridor handles are missing but I can see the templates, all levels in theory activated as well as construction view. I processed the corridor several times but still gone.
Any ideas?
Thanks everyone in advance.
The fix for Power Geopak was to turn on the 3D view in the 2D model so you can see the corridor handles, type in "Corridor Reattach" in the key-in command box, follow the prompts to select the corridor, HALN, and profile so it could reassociate the corridor elements. Still not sure what is making the handles disappear, but they should reappear in the 2D after that.
