ORD 2019 R2 - Complex By Through Points
I need to rework the superelevation along an existing highway and am having to eye the best fit centerline I can.
I am currently trying to intersect the mid points of as many perpendicular construction lines as possible. As you can see from the image below it is not always 100% accurate.
If I could specify points that my horizontal geometry could run through that would be useful, a little like the Through Points option for the B-Spline tool. Could a Complex By Through Points tool be added in a future release? (If this tool already exists please let me know)
Josh
  • Would a best fit be sufficient? I would try the Define by best fit. I also have been able to do a best fit on a MicroStation spline element before for a drainage centerline. This seems to be pretty dependent on geometry however, sometimes I just get tangents and larger curves that are disconnected.
    Steven Litzau, P.E. - Senior Consultant
    www.envisioncad.com
    ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33
    Power GEOPAK / Power InRoads - 08.11.09.918
    Civil 3D - 2021 / 2022
Reply
    www.envisioncad.com
