Is it possible to label multiple different alignments in the same cross section sheet. I'm trying to create a text favorite that will label alignment name, alignment station, and elevation. I have the elevation labels working. the stationing is not correct and the alignment names are all the same as the alignment that i'm using to create the cross sections from. Any help would be greatly appreciated.
Please update when Bentley plans to resolve Defect 1025638 as it is still not working as OP requested as of 10.11. The link you provided is broken and there's no way to look up defects by number.
This defect has been resolved. Should be fixed in 10.11. If you're seeing a problem with the point names appearing incorrectly in XS model, please file a service case and share you data set.
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Was this ever resolved? I cannot get the XSC to label and station the multiple alignments that are within the named boundary. It pulls the alignment name and station of the named boundary. Using 10.11
As far as I know you can only label the alignment name and elevation. The stationing is based on the named boundary. That would be great if we could label stationing on all alignments in cross sections.
