I am trying to place a background mask in my plan labels and have only partially succeeded. Is it possible to mask the entire label? If so how? The masked portions are done with a text style.
Hi Rick
The one aspect of the problem has been fixed in that there is now an option to use the text style background for fields. It may be that it is not enabled on your PCs. In OpenRoads Designer 2021 R1, I can confirm that that fix is still working.
If you go to File -> Settings -> User -> Preferences -> Text, there should be a check box for "Apply Field Background from Text Style" that needs to be enabled. If the text style used has a background that acts as a mask, it should apply to all fields.
Kind Regards
This resolved Rick's issue: (+) How to remove background Text Mask from Drawing Model Annotations - OpenRoads | OpenSite Wiki - OpenRoads | OpenSite - Bentley Communities.
