ORD Civil KEY-INS - Where can we find an overview
For a custom Ribbon it would be fine if there was an overview of Civil Key-ins.
For Example:
-How can we set a Feature Definition to a curtain one?
-How can we attach a curtain Corridor to Geometry?
Louis
  • Thanks for replying. SEE ANSWER BELOW
    Sorry for bothering you but, this is what I see when I use the keyin ---
    I did see the link you sent and tried all.
    I did notice in the keyin that I’m using – if you type in macro>vba>run
    Just figured it out the keyin is the same but, you have to add (macro) in front of the keyins that are in the link you sent also, in the help file.
    MACRO VBA RUN [Projectname]Modulname.Subroutine
    MACRO VBA RUN [Projectname]Subroutine
    MACRO VBA RUN Subroutine
    <![if !vml]>https://d.adroll.com/cm/aol/out?adroll_fpc=8db2eaa6c5bcd74a49ec9a2d0e841ab9-1581122204564&xid_ch=f&advertisable=R34N6MJTEVCATGBJCHBNKU<![endif]>
    Thank you,
    Garry Spivey | Jacobs | Highway Design Technician Specialist | Digital Delivery Lead
    People & Places Solutions | O: 1.773.458.2859 | F: 1.773.693.4896
