Hello to allI was using Open roads 2019 release smoothly .After getting notification for 2019 release 2 updated the software after which the software started some problems due to which i had a fresh install and updated it again to the current version 10.07.01.32. It has again started to giving problem as every time i try to modify or change a template on a corridor, the template leaves orphan element such as base layer, curbs. which cannot be deleted even if the whole corridor is deleted . if somebody could help what is the reason and why the element cannot be deleted.
Please see
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/185357/availability-of-2019-release-2-10-07-01-32-opensite-designer-openroads-designer-openrail-designer-from-bentley-software-download
We have been working hard to provide a fix to correct this and appreciate the inconvenience of waiting puts on you. Rest assured the new version is imminent and you will be seeing notifications here in communities and in Connection Client.
With regard to how to address. They can be cleaned up / removed with the workaround of moving to a specified level (that you can turn off to clean the display) and then delete the specified level with keyin - LEVEL ELEMENT DELETE {levelname}
Ian
Thank you for Information.
