Hi There,
I am a beginner in Openroads and having this weird problem that I am not sure what went wrong.
We have a model with library setup. I created our storm sewer design in subsurface utilities and all CBs, MHs, and pipes are set to the desired feature definition.
Just starting from yesterday, when I place new nodes in my drawing, the feature definition I used before does not come up anymore and my hydraulic analysis under the utility properties is empty now. I checked the properties of the CBs I created previously, they show up as the desired feature definition.
Not sure what went wrong and what steps I need to take to fix it. Any thoughts would be greatly appreciated.
Della
Are the new nodes you are placing in the same drawing and model that the first set of CBs, MHs and pipes were created in?
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022 / 2024
Hi Steven,
Yes, they are in the same drawing. I found a solution. It was a two step process.
1. looks like my library was partially missing in my working drawing. So I copied my library to my working drawing under explorer.
2. Still not working. Then I found bring up the set definition toolbar and it allowed me to change in the toolbar to the correct features.
