As per above subject, alignment modification is not being achieved.
Has it been part of table editor only and dynamic changing of alignment is discontinued in OpenRoads Designer or am I missing some option?
Hello Sandeep,
You can access table editor from Geometry > Common Tools > Table Editor.
Please let us know if you have any questions on the same.
Purva Lakde
If I am understanding you correctly here, you're not seeing the manipulators that provide editing. There are three settings that could impact this: Make sure that "Disable Handles" is not selected and that "Identify Elements Automatically" and "Pop-up Info" are selected in the AccuSnap settings.
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022 / 2024
Answer Verified By: Sandeep Sachdeva
Thanks Steven It worked.
Good to hear! You are welcome.
