Hey all,
I am having issues trying to place a Named Boundary from a Drawing Boundary. I have figured out that the drawing boundaries are located in the DrawComp.dgnlib file that is delivered with the Bentley Install. I have been trying to re-create these drawing boundaries from scratch with no luck.
-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Here is what I know and have done:
Figured out that the “Civil Types” (Civil Plan, Civil Profile, and Civil Cross Section) are placed in 3D they seem to work fine as shown below
Whenever I chose to place one in a 2D view I don’t see any Drawing Boundaries. When I create the Drawing Boundary using the Drawing Type “Detail” I am able to see when I try to place the named Boundary.
But when I got to make the actual Drawing Model and Sheet model using the Create Drawing function I am not able to select a Drawing Seed
So what I have gathered so far is that the Drawing Types that have Civil in them can only be placed in a 3D view. The other types General/Detail can be placed in a 2D View. There are not Drawing Seeds to select from like I was able to above with the Plan Sheet. Also, the Bentley Delivered DrawComp seed file has to be renamed or it will show up with all of their drawing boundaries. I have it renamed in this one to show what we have. They have both 2D and 3D drawing boundaries. I made a video of the workflow I was using as well to better communicate my process.
https://www.youtube.com/watch?v=0KsBR-gKUuQ
Any help is appreciated. Thanks!!
Edit: the file name is DrawingSeed.dgnlib****
