Is there any command in Geopak drainage to delete all the nodes in one go ? Or we have to delete them one by one by selecting "delete node" option?
Any idea?
Vineet:
Can you not select a group of nodes and then execute the "Delete Node" command?
Mark
Hi, thanks for reply mark.
No, we can not select nodes & delete them in a group. because after selecting group of nodes and executing "delete command" it will come back at same point to select & delete single node.
Well, as an ORD/ InRoads user I thought that such was worth a shot at least. And I suppose that you have executed the command and then selected a group? Is there a command under the one (or somewhere there) you have selected which allows you to select a group? Just trying to think of anything here which might help you out...
Mark,
Tried both the ways but can't select multiple at a time.
You can select multiple elements using the Drainage Navigator and then click Delete.
