Is there a way to find surface areas of fill at specific elevations using the 3d model? For instance, we are designing a service road that will have 15-25 foot of fill and we need to use a chemical compound to make the compaction quicker. They are going to lay down a one foot lift of dirt, then spray on the chemical. We need to give them the areas of all those 1 foot lifts. I was curious if geopak lets you take horizontal slices or something similar. Any help on this would be great!
Thanks in advance!
Brent Mould
CDM Smith
I presume in GEOPAK that if you have the model, you have or can create a terrain. GEOPAK will visualize the contours as MicroStation elements, the contours would be the area at each foot elevation.
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022
Steven,
Yes, that would show the locations of each elevation, but is there a way to calculate the entire surface area of fill at the elevation, ie 621, 622, 623, etc.?
oh, i think I see where you are taking this. Visualize the contours, then I can fill between the contours to get the areas. I will try that. Thanks!
