Having a cell library problem with the refresh version of ORD. We have 1567 cells in our current library. If I try to place a cell, ORD will eventually crash out with no errors displayed.
For testing I have broken up the single library into alphabetized libraries - Cells/models beginning with numbers in its own library and each beginning letter in its own libraries. That has ended up being 24 cell libraries.
When attaching each library individually, I can place a cell. Of course the larger libraries take a little longer to load but it does load. We have a "toolbox" dgnlib that we use for our "standards" and it appears to work ok with the separated libraries.
Previous version we are on, 10.07.00.56, does not appear to have this problem.
Due to to an over site we realized we had a bunch of models in our "toolbox" dgnlib and the refresh was taking up to 12-15 minutes to open a file while it was visibly processing each model on the screen. It appears that each model in the .cel files are having to process each time also. It just bombs when they are all in one library and I activate the Place Active Cell tool. Does not work with our "toolbox" either.
I have used new files to import the models into and the whole library is a new file also.
Has anyone else run into this problem?
Robert
This has been reported as a defect to product development and they are looking into a solution. The defect number is 1061591.
A fix for this issue has been made available. More information at the link below:
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/43982/civil-products-update-for-openroads-opensite-and-openrail-v10-07-03-18-to-fix-slowness-loading-large-cell-libraries
Hi Kevin,
Can I request this gets pushed to CONNECTION Client to automate distribution to our teams?
Great to see the move to Patches to resolve issues in interim of product releases.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
can this post be made Sticky in the forum?
