Is anyone else having a problem with the Cross Section Preferences in PowerGEOPAK Select Series 10 08.11.09.918? None of the preferences are loading, nor can we save a preference.
Please check this wiki: https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/31445/xin-is-blank---preferences-and-styles-lists-are-empty
That did not solve the problem.
You installed the MSXML4 and it still doesn't work?
Is it a fresh install or was it working before and stopped recently?
Does it happen with any xin file?
Have you tried on a different machine?
If you can send me some screenshot of the issue it may be useful.
Today we tried it outside of ProjectWise, and it worked. We tried it again inside ProjectWise, and it worked. So no clue what happened, but it is now working.
