I have been trying to move from InRoads Suite to OpenRoads Designer. I have a design in ORD which has two intersection realignments and a main drainage way relocation. I have three road corridors and a ditch line corridor created. Now I have to mash all this together and figure out how I'm going to get it in format I can layout in the field. Should be a button to create a terrain from a corridor but I haven't found it. Assume I need to create terrains from all four corridors then merge them into a final surface for the layout calcs. Also having trouble creating the cross sections. I liked the old way of attaching them to the drawing.
I know that's a lot of rambling but that is what my mind has been reduced too. I'm Trying set hubs on the ROW line at my cross section stations and do an offset w/ cut/fill to ditch, EOP, CL etc. How do I get a report with coordinates for the hubs and XS points.
Would a station offset report work for you? There's a mention of the workflow involved found in this thread.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/167361/specifying-offsets-for-reports-in-ord
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
That link seems to be right direction. Think I can download the reports into Excel and massage the data to get what I need.
Answer Verified By: aucivil
