Is it possible to define a curve by length instead of radius in order to match existing plans and the correct curve PI?
Thank you!
You could work out the radius by the curve's degree of curvature - some manual wok, but it should get you what you need.
Answer Verified By: Taylor Brownlow
In InRoads you could simply use the curve calculator. With OpenRoads you'll have to embrace the 70s revival: pull out your calculator (or slide rule). R=(180L)/(Δπ)
We found that there is no "native" way to do this.
This is just another reason I hate this program.
