I don't normally use Microstation for 3D. Please help. I need step by step instructions for dummies. Haha. Thanks.
I do not have Power Geopak or InRoads either.
I think you need Geopak or Inroads to work with .las files to create a tin
Idaho Red
I do have Geopak, I just don't have the Power pack. I just have everything I have listed above. But I use Geopak every day to generate cross sections and profiles, I just never have needed to create a surface TIN until now. There has to be instructions to create surfaces using the set-up that I have somewhere. If I have to have more software installed, I can request it, but I think my company decided not to do the Microstation Power Pack or Open Roads.
What you showed earlier looks like the plain MicroStation Terrain tool.Make sure that Geopak is activated. I don't think the civil tools will show up if it isn't.
If your Task dialog isn't already open, you can open it by going to Workspace -> Preferences -> Task Navigation and click on "Show Main Task Tools".
When that opens, you *should* see a list of task tabs. Look for "Civil Tools". These are the SS4/OpenRoads-type tools that go along with the regular Geopak tools in SS4/SS10. That should show you another list of task tabs, including things like "Analysis & Reporting", "Horizontal Geometry" and (what we really want to see) "Terrain Model". Click that tab, and you will see a couple of dozen terrain-type icons.
The first tool is "Create From File" and one of the file type options is going to be LAS files.
MaryB
cliff, thank you so much. Now I need a tutorial on where to go from here.
I have several POD or LAS files that I have edited the preferences the way I want. Now I want to create a TIN from the points. Am I getting close? Thanks!
