Is it possible to profile an element to a tilted plane, equivalent to the old DESIGN 152 command in MX?
Not that I am aware of - I have worked around this by making a terrain to represent the tilted plane, and draping.
As Mark suggested only way to create a tilted plane is to create horizontal geometry around the area needed and the create the vertical gradients needed for the tilt. Set these verticals as active then add to a terrain using Terrain from element.
Then to Section in to your profile use quick profile from surface to add the tilted plane to your vertical design.
This is how I do roundabout design in ORD and have built it into my own Roundabout Civil Cells
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
