I'm trying to import a utility model from SS4 to OpenRoads. I followed the instructions here. I load my .xin file, my .dat file, and my .sdb file. I didn't load a .idf file, but I'm not sure if that's necessary.
Here are the issues I'm having:
1. There is nothing in my Project Configuration dropdown menu to choose from. ( I guess I'm not sure if this is causing issue #2 below).
https://walmartone.me/
Follow this link and watch the video and see if it helps clear things up. The video was don't in SS4 but should be the same. Also if you have the SS4 utility model then you can export it. (Export SUbmodel) then import that into ORD.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/17682/video-import-drainage-project-from-inroads-s-s-geopak-drainage-or-mx-drainage
Thanks for sharing this amazing information.
I have also same issue any suggestion for this so please reply. Thanks in advance. mymorri login
