I have a series of client supplied road alignments (LandXML format) that when displayed in OpenRoads Designer and annotated with the ORD PnP toolset, several of the profiles will not annotate the vertical curves. At first, I thought the problem was with the client supplied workspace, but then after trying two other client workspace and Bentley’s own “Training” workspace, the issue persists, and we cannot get ORD to annotate some of the vertical curves.
Does anyone know of a issue, toggle, or other setting that would keep vertical curves from annotating in ORD.
Thanks in advance!
Chris:
As of the 2019 R2 of ORD, the vertical curve sets do not annotate with all of the information we had become used to with InRoads SS2. The VPC, VPT, and VPI stations and elevations annotate as do the curve length and K Value, but the curve set length leader and leader arrows do not appear. Is this the issue of which you speak? Bentley is working on this issue and a SR exists to resolve it. The issue- as I perceive it- is the variable length from VPC to VPT and the fact that annotation groups do not exactly work conducive to that notion.
Mark
