Hey Robert - have you guys made a change to the latest Water & Sewer so that it does not require the DDB file to work?
Robert Garrett: Neil Drainage, Water and Sewer can all use the DDB file but it is not mandatory.
Neil
The D&C Manager automatically loads the default DDB file unless, there is a different one that has been manually selected from the D&C Manager file > open command which then remembers that in a resource file. If there is no resource file and the variable GPK_ACBOOK_DDBFILE is set to load a custom DDB file, this is the DDB file GEOPAK will load. To force the user's custom DDB file to always load the variable can be forced by adding the variable GPK_FORCE_ACBOOK_DDBFILE=1 following the GPK_ACBOOK_DDBFILE variable. If this is set all of the tools in GEOPAK that use D&C Manager will automatically load this DDB file.
Thanks for the guidance on setting the default DDB file Esther. Once I get the drainage and sewer tools to use my DDB file I also need to map the settings in those libraries to my customized D&C setup. That is where I am needing guidance at this point. It would be nice to make those edits globally or in some type of external editor for global edits if possible.
Neil Wilson (aka Neilw)
Power Civil v8i 08.11.07.245
AutoCAD Civil 3D 2018
You can make most of the edits you have mentioned in external files. There are a couple different options and my recommendation for which one you should use depends on the version of GEOPAK you are running and also the different types of edits. If you are simply going to use the same item but you want it to look for a different cell name, you can export the database or only a portion of the database to an external ASCII file. However if you are editing drafting standard items, only the top 3 dialog' information is maintained in this option. If you are using GEOPAK XM or GEOPAK V8i you have the option to export to an Access table and do global edits in Access and then reimport. But you most be careful to maintain the table formats. You can access these options from the D&C Manager Dialog File > Save As and then File > Merge to reimport. Another thing I would mention is that D&C Manager will look for cells, linestyles and levels according to your configuration variables, so you should have these paths set prior to editing the DDB file. Also if you are defining key-in commands, don't include paths, let your configuration variables do that. I hope this helps you get started. D&C Manager can be very powerful and do much more than most users realize but of course all of that is dependent on the setup of the database.
Sorry to resurrect another old thread but this seemed the most appropriate.
I am trying to edit the Profile Drafting Preferences to change the placement location of the K-value and the SSD in a Vertical Curve label. Unfortunately, I have been unable to find where these preferences are located. See screencaps below. Can anyone help?
