Is there a setting in geopak civil engineering suite and microstation select series 4 to have text show up as white in the drawing and automatically print black?
Depending on your color table, pen table and print driver, that's what color 0 usually does.
There's a whole forum dedicated to printing and plotting issues. If you edit your post, you may see an option for More... that will allow you to move your post over there.
MaryB
I usually use an online pdf where I can easier create forms. I know that this is a Bentley forum, but if someone needs our help then it will be better to help him. It's always easier to use an online pdf form where you will easier understand what to do and even learn how a pdf form is working and what operations it can do. When I have made my site, this company https://pdfliner.com/how-to/how-to-compress-a-pdf has helped me a lot, to paste the information as interesting and useful as it's possible. Thus I was able to post the most useful information about the products I am selling in the most visual place and secondary information or unnecessary one to post somewhere behind.
If you aren't using Bentley software to actually print your plans, we can't help you. You will need to ask whatever company you use to print. We can only assist with Bentley software, not some random online website.
Normally - in Bentley software - the standard color "0" does print black on a white background. But since you aren't using the Bentley "Print" function, I have no idea what could help you.
Why do you not use the Bentley "Print" function? They have a a very good PDF print driver, and then you can use pen tables and design scripts to resymbolize your elements to your heart's content.
