Hi
When I generate the cross sections sheets, the bottom grid axis in the cross sections are not adjustable as per the section.
My proposed design is going below the grid axis in the cross section. Please find the snap shot below showing the error in red color area.
Pavan. N
What software (and version) are you using?
Hi Mark
Thanks for the reply.
I am using Open Roads Designer Connect Edition-2019 Release 2 Update 7 - Version10.07.03.18
When placing the Named Boundary for cross sections, are you specifying a 'Bottom Clearance' in the dialog? That should prevent the issue you are having.
Could you please confirm Bottom Clearance in the Named Boundary represents A or B in the snap shot below
'B' - it is the 'viewing' window buffer at the bottom.
To me, 'A' would be the distance from one section window to the other, which is defined by the configuration variable 'CIVIL_CROSSSECTION_TOP_TO_BOT_SPACING'.
