hej
I am using ORD 10.07.03.18, with Geometry Connector Tool I cannot select neither Begin nor the End Element. I am quite sure that in the previous release (before refresh) it worked as desired.
Are you able to use this tool successfully? I wonder if that's general bug or it is my installation that needs to be fixed.
mvh
Adam
Hi Adam,
I am able to work in Geometry Connector in ORD 10.07.03.18. Looks like a system specific issue to me. Is it happening on all the projects ?
All files are affected. I am prompted to select Begin/End Element, then to Accept it (info in status bar), but Geometry Connector tool is not populated with selected elements. Had no such issue before upgrading to the "Refresh" release.
Best,
OpenRoads Designer 2023 | OpenRail Designer 2023
Can we check this issue over Team Viewer or Skype for business meeting? Please share your official email ID, to send the meeting invite.
Adam, it works for me but snap is required when selecting the elements i.e. active AccuSnap or manual snap (tentative). Otherwise after data point in answer to Accept Element nothing happens. The same requirement seems applicable when selecting alignment in Transform function. All this in both ORD 2019-R1 and R2-Refresh.
Mariusz
OpenRoads Designer 2022 R1
Answer Verified By: Adam Wieczorek
Correct, snap did the trick. I must have accusnap enabled when tested this in previous release.
Thanks.
