I turned on 'Use Position Mapping' in the user settings (Settings->User->Preferences->Position Mapping). I can only get the tool commands to active if I use the ribbon tab command first (ie. Alt + G for Geometry), then the letter or number combination. Is this the intended workflow for this tool or do I have something set up incorrectly?
Are you already on the Geometry tab, if so what is the dialog with focus.
It shows that I have focus on "Home" (House icon in the bottom corner). The key stroke commands don't interact with the Ribbon.
I have been trying to do this with Main as "1234567890", Tasks & Ribbon as "123456789", and Tool Settings and Menus as their Defaults. This results in the pop up menus not working.
If I change Tasks & Ribbon to be anything other than numbers they seem to work.
The tools themselves seem to follow their own key in commands and even when I do "Import Local Copy" in the Customize Ribbon settings, I am unable to change what letter they use.
