What strikes me initially is that when the numerical seperator is a Point in Windows and in ORD, in the Material editor (3D model - Visualisation Ribbon - Material Editor - Pattern Map) the seperator is a comma. In MicroStation the comma - point problem doesn't appear (?).
After editing materials in ORD, the Template Library becomes Corrupt:
Good (before editing material in Material Editor)
Corrupt after editing material in Material Editor (Templates are flat)
Please fix this very serious bug. People can get serious problems when this happens.
Hi Louis,
Is it the same issue as this:
https://communities.bentley.com/products/rail_design/f/openrail-forum/147159/flat-itl
Mark
Hi Mark,
Good to see I'm not the only one with this bug. Now we know a cause, I hope Bentley comes with a solution quick...
Regards Louis
It should be fixed in next release 2019-R3 (10.08.xx.xx)
Editing a material could be a source but it is not the only one. I faced the issue without having edited material.So hopefully the fix will fix everything
Thank you very much jpln.
When You open your *.itl file with any texteditor and substitute the separators the template library probably works correct again.
