I have been using Geopak for a project where I need to change some of the areas that I assigned to some inlets. I changed those areas in the dgn and then I used the area tools to assign them to the inlets. Those inlets it might have or not areas assigned before.
The problem is when I update the areas (in the same dgn or in a completely new) from the gdf after saving, the areas that are drawn do not reflect the changes that I made. I repeated 3 times the process just to be sure I was saving and assigning the areas properly. Also, I checked I saved the files in projectwise correctly (I made a test in my c drive just to be sure that it was not a pwise problem).
Anyone with the same problem? What can I do?
David
