I have the superelevation assigned to the corridor but certain templates are not being controlled. The Lane2,Lane3 and PGL are all flagged in the templates. In the properties dialog those points are highlighted. Any thoughts on why this is occuring? Thanks
I see you have 4 lanes of super going, but this appears to be a 2 lane road from what you have pictured. Correction: Actually, I see you have 4 - 11' lanes....
However I do not see where and how they are controlled. Can you clarify/ show your intended superelevation sections (sta. begin/end, cross slopes, lane) ? This will better compare and see if what you have in the model is correctly inserted.
colliersengineering.com
Answer Verified By: Taylor Brownlow
I had to delete all sections and start over and it has worked so far.
