Corridor object window doesn't show up only in one files. Other files not problem. Is it a problem with the file?
Hi Iwona,
Can you please send across the file which has got the issue. Also, what is the version of ORD you are working on?
Hi Amita
Thank you for replay. It was problem with software installation. Uninstalling, cleaning Temp folders and installing again solve problem
