terrain model from multiple corridors
Looks like the way to go about it is to change the design stage of the corridors to final mesh, create a file and attach the corridors to that file. then use the create terrain models from element tool, choosing the final mesh….but what about the civil cels. how do you get a final mesh of a civil cel to add to the terrain model. thanks for your help, brian
Parents Reply
  • 1. No, I do not mean 'Select by attributes'. In the OpenRoads Modelling workflow > Terrain tab > Miscellaneous group, there is 'Graphical Filter Manager'. Use this to define what you want included in your terrain.If you have a consistent convention, put this graphic filter in a DNLIB so that it is always available to all your users.
    2. Yes.
    3. Yes. All the files are referenced, and the graphical filter will create the terrain.
