I am trying to create cross sections for a few various size corridors. I started with the simplest/shortest corridors. I have a template that is controlled by parametric constraints as to what object (curb and gutter, ditches, etc.) will appear. One of them is a ditch with a driveway. I only want it to appear at a specific station and have identified that in inRoads using the parametric constraint. I then set the midpoint of the drive as a key station.
Then I created cross sections a set it to display key stations. It does but does not show the driveway instead it shows the same ditch profile that is both before and after this driveway. What can I do to make it show up. The odd thing is that it did once yesterday and then today when I rerun them it will not.
inRoads V8.08.00.46
Neal,
Project Line to Surface command will permit you to snap to the Proposed EP and then project at a specified grade to the OG. This can assist in determining the drive limit without having to profile each drive separately.
As far as the CDR issue, I would need to see what is going on in order to de-bug the problem.
HTH
Thomas
