Hej
We have created named boundries representing construction phases and now would like to assign Item Types to CAD elements with Asset Manager by Named Boundry.
Firstly when I cut meshes with Quantities By Named Boundries then Asset Manager returns infor that no elements found in Named Boundry and no Item Types are attached (tried with both options: inside and overlap)
Secondly what we need is to have Named Boundry Name to be attached to CAD elements as Item Type Property, so every CAD element is tagged with Named Boundry name, eg for the sake of schedule simulation, (4D, 5D, etc.
I wonder if any of you here had similar idea to tag CAD elements, and an issue with using Asset Manager with NB.
Thanks in advance for your help.
/Adam
Adam,
Any luck with this?
I've just started to set up named boundaries with the plan to assign Marker Post references to objects.
When I looked at the named expressions for Named Boundaries, I noticed that Name wasn't something that comes up. But description is. Haven't tried this but will be very soon.
If I get something to work I'll share the solution.
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Nope. Unfortunately I cannot find a way to assign elements with an Item Type that reads from Named Boundary Name property. It would need to work in a similar way as assigning eg. station and offsets from the reference Alignment.
Best,
Adam
OpenRoads Designer 2023 | OpenRail Designer 2023
I found {ORD_Sheet_Name} in the _AssetTemplate worksheet in the standard book. But this isn't working for me at the moment.
Tried ${ORD_Sheet_Name}, {ORD_Sheet_Name}, ${Sheet_Name} & {Sheet_Name}. As well as all in CAPS.
Daniel Ahern Any ideas
