when I'm working on a 3D roadway project. should the profiles be in the roadway (2D) design file or in the 3D model design file? also does it matter where it is located
Please start a new thread with your question. I believe that you are talking about something other than the original poster, and answers to their questions will not address your concern.
When you do create your own post, please make sure to identify which version of the software you are using, which tools are giving you trouble, which resources you have been using to generate your design, and a lengthy description of the problem. Your single sentence does not give much detail for us to be able to analyse and help you.
MaryB
its inroads series 2 during corridor creation it saysSAYS IMPERIAL UNITS USED WHILE CREATING THIS LIBRARY
please help
its the roadway designer tool..am having problem with the corridor
