Alpha Codes
How do I create a comprehensive list of Alpha Codes?  I am transitioning to OpenRoads.  The Alpha Codes that my surveyor currently uses in the field does not match the Alpha Codes set in my DOT delivered workspace.  I would like to create a list with the description and corresponding Alpha Code such as this:  EXISTING FL OF CONCRETE PIPE...………. EXFLRCP.  Is there a way to do this?
