I just updated to version 10.7.3.18 and am now getting this error periodically. It has happened when first opening a project file after the update and when right click holding and changing the view.
Also is it saying to run cmd with the command "OpenRoads Designer/regserver"?
Hi Taylor,
You mention that this message is returned when first opening a project file, with a subsequent launch of the same file, do you receive this message? Have you tried to repair the installation or reinstall?
Sanders
I had a user with this same problem. I opened a command prompt with admin privileges, and then navigated to C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition\OpenRoadsDesigner . The typed in openroadsdesigner /regserver . That seems to have fixed it. Next time the user ran OpenRoads Designer, it worked without getting the error message.
can you elaborate how did you resolved the issue? did you used "run" or cmd ? if cmd then what exactly i need to type in or copy. kindly explain.
I typed "Command" into the windows search bar in the lower left corner. I then right clicked on Command Prompt and clicked Run As Administrator. I entered the admin username and password. In the command window that came up, I then typed in:cd \cd program filescd bentleycd openroads designer connect editioncd openroadsdesigneropenroadsdesigner /regserver
This worked! Thank you!
