VBA rejected the OpenRoads Designer Application Object
I just updated to version 10.7.3.18 and am now getting this error periodically. It has happened when first opening a project file after the update and when right click holding and changing the view.
Also is it saying to run cmd with the command "OpenRoads Designer/regserver"?
  • This worked for me too. The folder structure has slightly changed so I had to add in an additional change directory command
    cd \
    cd program files
    cd bentley
    cd openroads designer connect edition
    cd openroadsdesigner
    cd OpenRoads Designer CE 10.10
    openroadsdesigner /regserver
    Additionally, you can also just type in: cd C:\Program Files\Bentley\OpenRoads Designer CE 10.10\OpenRoadsDesigner and skip a bunch of steps (your directory might be slightly different depending on the version you have)
  • Hey i had an user to try a clean install and it solved the issue
    These are the standard steps to do a clean install
    Please try to uninstall ORD (from Apps and Features)
    Make sure the below folders are deleted before trying to reinstall:
    C:\Program Files\Bentley\OpenRoads Designer CE 10.11
    C:\Users\YOUR USER\AppData\Local\Bentley\OpenRoadsDesigner (If you have any User preferences that want to keep, please make sure to do a backup of these folders)
    Please also go to the Registry Editor and delete these folders:
    Computer\HKEY_CURRENT_USER\SOFTWARE\Bentley\OpenRoadsDesigner
    Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Bentley\OpenRoadsDesigner
    Reboot the system
    Then try to reinstall ORD with Administrator's rights (right click >Run as Administrator)
