I have loaded Templates, levels, feature definitions and symbologies in the attached dgnlib. For test I have imported the attached text file which is in Point, Northing, Easting, Elev, Code format.
But i didn't get the linear features connected, all the features showing in Red.Also the symbols are not showing.
Can anyone check my feature definitions and symbologies are correctly loaded or not. Also why the cells are not loaded automatically event though i have kept the cells in the proper path as defied in the workspace.52a.csvFeatures.dgnlibLSS_V8iCells.cel
What workspace are you using in ORD? What is the 'proper path' for the cell library? Do you see the feature definitions listed in Explorer under 'Standards'?
Hi Mark,
Thanks for looking into the matter.
I am using the below workspace, created from the default provided metric workspace:-
yes I can see Feature definitions and symbologies in ORD explorer:-
The cells are copied in the below path:-
Your feature definitions are not survey feature definitions. In your screenshot, note the 'Survey_Settings_Features' dgnlib file. Survey features are separately defined.
Thanks very much for your valuable input.
How can we bulk import survey feature definitions from XIn file.
Ilyas
I have not dealt with XIN files - but the following may be a good place to look. Step 4 - Feature Migration
https://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=111346
