I am working on a GEOPAK model and cant analyze the network as it keep showing this error message:
Errors Preclude ComputationsError Computing Link Hydraulics for Link 3-1 required for NetworkErrors Preclude ComputationsError Computing Link Hydraulics
Link 3-1 referred to in the error message is the first pipe at the upstream end of the network. I checked all the areas, nodes, links and all looks OK. please can you advise? I cant understand what is this about.
Make sure there is a node at each end of that pipe. Make sure the link is going from upstream to downstream
Hi Beebe,
Thanks for your respond.
The nodes and links are all checked out, when hitting the "Design" option the model work fine, but when I lock the size and elevation and run as "Analyze" it gives the error message mentioned above. I have 5 storm sewer systems in this model, and they all have the same problem, any other solution I may try?
Would it be more helpful if I share the "gdf" file with you? can we contact directly via email?
Send gdf,dgn,cel,dlb
Please can you share your email? you may drop an empty email to sura.alshami@Jacobs.com
